Document Server Address?
Postby deljones » Wed Jul 12, 2017 7:00 am
Hi All
Trying to get my Nextcloud 12 to integrate with my PERSONAL ONLYOFFICE account...
It works only one way. I can create a doc in ONLY OFFICE PERSONAL and it appears in my NC 12. To go the other way, NC > ONLYOFFICE I need the document server address?? The ONLYOFFICE app is installed correctly in NC...
Many thanks
Del
deljones
Re: Document Server Address?
Postby Alex » Tue Jul 18, 2017 7:51 am
It should work in one direction. Your NC12 instance should be connected to your own ONLYOFFICE Document Server instance. ONLYOFFICE PERSONAL cannot be used for the integration with your NC. You cannot integrate ONLYOFFICE PERSONAL document editing service into any third party application.
Alex
Return to Issues
Users browsing this forum: Bing [Bot] and 1 guest
