Data Container with Traefik
Postby amiveth » Tue Jul 17, 2018 8:45 pm
As the example docker-compose file in the repository on GitHub [1] suggests to use an additional data container. We named it «onlyoffice-documentserver-data».
On our Docker Swarm Cluster, we use Traefik as reverse proxy. Both services (onlyoffice-documentserver and onlyoffice-documentserver-data) are in the same swarm overlay network.
The incoming requests are forwarded to the onlyoffice-documentserver service, but returns the nginx error page «502 Bad Gateway», e.g. when requesting «https://<onlyoffice-domain>/welcome/».
In the log of the onlyoffice-documentserver service, we find the following entry:
2018/07/17 22:37:23 [error] 1673#1673: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 10.0.0.10, server: , request: "GET /welcome/ HTTP/1.1", upstream: "http://127.0.0.1:8000/welcome/", host: "<onlyoffice-domain>"
In the log of the onlyoffice-documentserver-data service, we find the follwing entry:
If we do not split the onlyoffice-documentserver into two services, it works as expected. We want it to be scalable (multiple instances in parallel), so I think that the data container is mandatory.
Any ideas what the cause could be for this issue?
[1] https://github.com/ONLYOFFICE/Docker-DocumentServer
amiveth
Re: Data Container with Traefik
Postby Kate » Mon Jul 23, 2018 9:09 am
We recommend you to follow our Server Forum dev.onlyoffice.org. All questions about the server version should be posted on this forum.
Kate
Return to Issues
