Adding time
Adding time
Postby BruceB » Wed Jun 17, 2015 3:16 pm
I don't see a way to add time if the timer has not been used.
Am I missing something?
BruceB
Re: Adding time
Postby Kate » Mon Jun 22, 2015 2:17 pm
Helllo,
You can edit the records, if necessary, using the Time Tracking feature. To do that, click the Actions icon to the right of the record you need to edit and select the Edit option from the drop-down list. The Time Tracking window opens. In the opened window you can check the total time spent on this task and make some changes: change time and date, select another responsible person, modify description.
To apply all the changes you made, click the Save Changes button.
We would like to recommend you learning the following instructions:
- How to track the work time efficiently, please, follow this link: http://helpcenter.onlyoffice.com/guides/track-time.aspx
- Automatic Time Tracking while performing a task, please, follow this link: http://helpcenter.onlyoffice.com/tipstricks/time-tracking.aspx
Kate
Return to Issues
