desktop editor
Tell us about your experience with ONLYOFFICE
desktop editor
Postby Denis1 » Fri Jul 29, 2016 2:48 pm
Hi
I use onlyoffice.personal and I am very happy to have found the system. It works smoothly and perfectly integrated with Google drive.
On my personal PC I downloaded the desktop application, but noted I cannot acces my Google (or any other cloud application for that matter) directly from my desktop. That although I am logged-in.
Is there a (paid?) option for me to use the desktop application and get acces to my Google drive files?
Pleases to hear back from you
Kind regards,
Denis Steijn
Denis1
Re: desktop editor
Postby Kate » Mon Aug 01, 2016 3:15 pm
Dear Denis,
Thank you for your positive feedback!
We would like to note, that there is no possibility to access the document files from any third-party cloud applications using ONLYOFFICE Desktop Editors.
You can learn visual and detailed instructions on how to get started with Desktop Editors and connect Desktop Editors to your SaaS portal, please, follow this link:
http://helpcenter.onlyoffice.com/desktop/documents/index.aspx
Kate
Return to Your feedback about OnlyOffice
