Tables
Tables
Postby bartona » Mon Dec 19, 2016 9:06 am
Hello
I have started to use Only Office desktop and have a problem with the document program
When typing into a table the text doesn't print out. All you get is the table outline
bartona
Re: Tables
Postby Alex » Tue Dec 20, 2016 11:58 am
Could you, please, specify the following so we are able to detect the issue you mentioned:
1) Version of your OS;
2) Version of ONLYOFFICE Desktop Editors you are using;
3) The step-by-step scenario of your actions;
4) The concrete moment the problem occurrs at;
5) Send us the screenshot which illustrates the issue mentioned.
We look forward to hearing from you.
Alex
Users browsing this forum: Bing [Bot] and 1 guest
