Printing Documents
Printing Documents
Postby jdardozzi » Fri Jan 23, 2015 12:44 pm
Apparently this feature of the document viewer only allows you to print to pdf. I can not select a printer option and even if my default printer is a machine on the network, the document viewer will only allow me to print to pdf. Is this a bug or something?
jdardozzi
Re: Printing Documents
Postby Kate » Mon Feb 16, 2015 10:27 am
Using the current version of ONLYOFFICE Documents you can print the document file to PDF format only.
If you have any ideas on the improvement of ONLYOFFICE platform, you are always welcome to share them with us on our Feedback page: http://feedback.onlyoffice.com/
Kate
Postby ricevans » Sun Apr 10, 2016 7:42 pm
Is printer support ever coming for the Chromebook version of this program? Kind of misses the point without the ability to print.
ricevans
Postby Kate » Wed Apr 27, 2016 11:42 am
All information on how to print your document, spreadsheet or presentation using ONLYOFFICE portal you can find following the links below:
Save/download/print your document: https://helpcenter.onlyoffice.com/onlyo ... nload.aspx
Save/print/download your spreadsheet: https://helpcenter.onlyoffice.com/onlyo ... nload.aspx
Save/print/download your presentation: https://helpcenter.onlyoffice.com/onlyo ... nload.aspx
Kate
