searching accross all documents and all onlyoffice modules
Postby pee » Wed Nov 19, 2014 2:14 am
the search functionality in openoffice really misses full text indexing (across all onlyoffice, documents, email, projects, crm, discussions, calendar, forum, wiki etc.)
That will greatly enhance open office as a knowledge and collaboration platform.
Any chance that this will be implemented soon?
thanks!!
pee
Re: searching accross all documents and all onlyoffice modul
Postby Alexander » Thu Nov 20, 2014 12:19 pm
Please note, full text indexing is available for projects, crm, mail and documents modules.
Also we have common search for whole portal.
Search for documents is in process of developping.
We have forwarded your suggestion to our developers, thank you!
Alexander
Postby pee » Sat Nov 22, 2014 11:40 pm
Thanks!
Hi, with FULL text indexing I mean searching INSIDE the documents
For example email search in onlyoffice 7.7.0 searches only for the text in the title, it does not search for the text inside the email !!
This is true for all other modules.
It would greatly enhance the useability of onlyoffice if it could search ALL TEXT INSIDE ALL MODULES (and not only in the titles).
There are several open source modules that can accomplish this with ease that onlyoffice can build in.
A very important one is to be able to search into pdf files as well, as most final documents are stored in that format.
As a rule, I would enable full text indexing/search for all data in the portal, unless explicitly excluded.
Is that in the development pipeline?
tx
pee
Postby Alexander » Fri Nov 28, 2014 1:38 pm
Thank you for your suggestion!
We have forwarded it to our developers for further consideration!
It wouldn't be implemented in the next version, but we will take it into account.
Alexander
Postby pee » Sat Nov 29, 2014 6:34 pm
thanks that woul be great, and greatly enhance the useability of openoffice !!
pee
