Disabling invoicing
Discussion of the "CRM" module
Disabling invoicing
Postby uros.zecevic » Mon Aug 24, 2015 11:51 am
i've done some research, but i haven;t found the solution. I can turn on the whole CRM segment (which i need), but i don't need the invoicing part of the module since we are using separate software for that. Or can i hide it at least?
uros.zecevic
Re: Disabling invoicing
Postby Kate » Tue Aug 25, 2015 8:00 am
Unfortunately, the current version of ONLYOFFICE doesn't have the possibility to disable / hide the Invoices section within CRM module.
Thank you for the suggestion!
We will definitely forward your suggestion to our development team for further consideration.
If you have any more ideas on the improvement of ONLYOFFICE platform, you are always welcome to share them with us on our Feedback page: http://feedback.onlyoffice.com/
Kate
Return to CRM
