user's input's field
Discussion of the "CRM" module
Postby anagnost » Thu Sep 24, 2015 12:17 am
How to check how many sign was entered in the form?
For example, all contacts has one a user's input's field with 10 digits, not more or less.
Thank you in advice.
anagnost
Re: user's input's field
Postby Kate » Wed Oct 07, 2015 8:49 am
All the user fields created on ONLYOFFICE portal can be found in the Settings page within CRM module. Please, open CRM module, find the Settings section, open Other settings menu >> User fields.
Would you be so kind as to describe your question in detail:
- What certain form do you mean?
- The concrete action you are trying to perform on your portal.
- Send us the screenshot which illustrates the question mentioned.
Kate
Return to CRM
