Timezone Problem on Ical Feed
Discussion of the "Calendar" module
Postby onurgucukoglu » Thu Feb 26, 2015 7:44 pm
Events are 2 hours ahead on Ical Feed
onurgucukoglu
Re: Timezone Problem on Ical Feed
Postby Kate » Fri Feb 27, 2015 1:25 pm
To avoid this problem, please, check:
- the "Time Zone:" settings of the ONLYOFFICE Calendar on the portal (ONLYOFFICE Calendar >> choose the calendar you need >> press the "Edit calendar" button >> "Time Zone:" section);
- the time zone settings of the third-party calendar, the events of which you have imported into ONLYOFFICE Calendar.
The time zones of the both calendars should be identical.
Kate
Return to Calendar
