New order in Milestones
Discussion of the "Projects" module
Postby marcin » Mon Apr 30, 2018 6:10 pm
Is there a way to reorganize the Milestones order, especially for the working with Gantt?
This is ruining the workflow completely if at some point one decides to add a new milestone that is supposed to be superior to already edited. It ends on the bottom of the list/chart.
As a suggestion I would also recommend ability to cross-link Tasks between Milestones. For the visuals.
Let me only add that the OnlyOffice is a great piece of software for having it on own server and holding full control over own data. A big thank you and accolades to you!
marcin
Re: New order in Milestones
Postby Kate » Sun May 20, 2018 9:47 am
We are glad that you like ONLYOFFICE.
Following this link you find the detailed information about how to manage your project using the Gantt chart.
As to your question about the ability to cross-link tasks there is possibility to create task dependencies within the Gantt chart. Here you find more information.
Kate
Return to Projects
