Project, Milestone and Task Status
Discussion of the "Projects" module
Postby tohcy@oanetwork.com » Fri Apr 03, 2015 4:54 am
Dear all,
I may be not aware if admin can customize the project/milestone/task 'status' ? Currently I saw from the pull down list in project menu 'Edit' & 'Close'
In actual project management, often we need a lot of of status to manage tasks that are distribute across, such as :
1) Project manager issue task to 3 engineers - Status = New
2) 1 of the engineer complete the task but required verification - Status = Delivered
3) 2 of the engineers are still working on the task - Status = In Progress
4) The project manager, then assign a senior engine to verify the task in (2), and upon completion, Status = Verified
5) The task in (2) then is officially closed, Status = Closed.
There are many more possible such as :
Investigate, Pended, On Hold, KIV
Kindly advise if the existing project module able to allow admin to self-customize up the list of status available ?
tohcy@oanetwork.com
Re: Project, Milestone and Task Status
Postby Kate » Mon Apr 06, 2015 8:59 am
Unfortunately, there is no opportunity to customize the project/milestone/task status using the current SaaS version of ONLYOFFICE.
We will definitely forward your suggestion to our development team for further consideration.
If you have any more ideas on the improvement of ONLYOFFICE platform, you are always welcome to share them with us on our Feedback page: http://feedback.onlyoffice.com/
Kate
Return to Projects
