Task start and end hour
Discussion of the "Projects" module
Postby albertotoplevel » Sun May 17, 2015 5:27 pm
Is it possible to define start and end hours when creating a task?
albertotoplevel
Re: Task start and end hour
Postby Kate » Mon May 18, 2015 9:41 am
Creating a task within the Projects module it is possible to set a desired date in the following format dd/mm/yyyy using the current version of ONLYOFFICE. Unfortunately, there is no possibility to define hours creating a project task.
Thank you for the suggestion!
We will definitely forward your suggestion to our development team for further consideration.
If you have any more ideas on the improvement of ONLYOFFICE platform, you are always welcome to share them with us on our feedback page: http://feedback.onlyoffice.com/
Kate
Return to Projects
