Management Information
Discussion of the "Projects" module
Postby mattz118 » Fri Dec 11, 2015 2:12 pm
Is there a way of accessing more detailed MI from Projects.
Highlight reporting is a key function of Project Management and being able to pull more detail from the reports section would be key for me.
Thanks
mattz118
Re: Management Information
Postby Kate » Mon Dec 14, 2015 8:40 am
Working with ONLYOFFICE portal you can manage your project using the Gantt chart and constantly monitor the project's progress using online office Reports system.
Please, follow the links below to learn visual and detailed instructions:
http://helpcenter.onlyoffice.com/guides/gantt-chart.aspx
http://helpcenter.onlyoffice.com/gettingstarted/projects.aspx#ReportingProjectProgress_block
All the information about the functions of ONLYOFFICE as well as all the instructions can be found in our Help Center:
http://helpcenter.onlyoffice.com/index.aspx
Kate
Return to Projects
