Tasks- how to get them to show up in a certain order
Discussion of the "Projects" module
Postby 5foldmedia » Sat Jan 09, 2016 4:36 pm
I have tried several ways to get my tasks to show up in a certain order, even putting numbers before each tasks under each milestone (01, 02, 03...), but aside from putting each task under a different milestone, I can't get them to show up in any particular order under milestones. Some of my projects have upwards of 60 tasks. I have long desired for us to be able to reorder them by drag and drop, but that seems to never happen...Is there any way to make sure that my tasks show up in the order that I want them to? Thanks for any advice you can give!
5foldmedia
Re: Tasks- how to get them to show up in a certain order
Postby Kate » Sat Jan 23, 2016 11:19 am
Working with ONLYOFFICE Projects module you can use the "Filter" and "Sort by" tools to classify your tasks by certain parameters.
Unfortunately, the current version of ONLYOFFICE doesn't have such possibility to adjust a custom filter.
Thank you for the suggestion.
We will definitely forward your suggestion to our development team for further consideration.
Kate
Return to Projects
