Task with time
Discussion of the "Projects" module
Task with time
Postby kohnout » Thu May 19, 2016 8:41 am
it is great I can create a task in project and see its history. laso this task is visible in calendar. BUT. What if I want to plan a meeting as a task - i need also TIME not only date. Is it possible to add time to task?
I know I can create an event in calendar separately but there is no linkage between them.
Any idea ?
kohnout
Re: Task with time
Postby Kate » Wed May 25, 2016 10:02 am
Using the current version of ONLYOFFICE there is a possibility to set a desired Start Date and Due Date to a project task in the following format only: dd/mm/yyyy.
We will definitely forward your suggestion to our development team for further consideration.
If you have any more ideas on the improvement of ONLYOFFICE platform, you are always welcome to share them with us on the Feedback page within this cloud forum.
Kate
Return to Projects
