Error with snap
Office suite for offline editing of documents, spreadsheets, presentations and collaboration
Error with snap
Postby clauded99 » Wed Apr 11, 2018 3:56 pm
I just installed OnlyOffice as a snap on Solus. When I first load the appI get the following messages and I can acces OnlyOffice fine afterward :
$ onlyoffice-desktopeditors
/snap/onlyoffice-desktopeditors/15/usr/bin/desktopeditors: line 61:  3136 Bad system call         cp -a $SNAP/usr/share/mime $XDG_DATA_HOME
ln: failed to create symbolic link '/home/myname/snap/onlyoffice-desktopeditors/15/.local-4.8.7/share/glib-2.0/schemas/*.xml': File exists
QStandardPaths: XDG_RUNTIME_DIR points to non-existing path '/run/user/1000/snap.onlyoffice-desktopeditors', please create it with 0700 permissions.
(process:3027): Gtk-WARNING **: Locale not supported by C library.
   Using the fallback 'C' locale.
Qt: Session management error: None of the authentication protocols specified are supported
XmbTextListToTextProperty result code -2
After reboot I get the following error and OnlyOffice wont start :
cannot change profile for the next exec call: No such file or directory
My snap env:
$ snap version
snap    2.30
snapd   2.30
series  16
solus   3.999
kernel  4.15.15-63.current
$ snap list
Name                       Version     Rev   Developer     Notes
core                       16-2.32.3   4407  canonical     core
onlyoffice-desktopeditors  4.8.7       15    onlyoffice    -
$ uname -a
Linux pt-00611 4.15.15-63.current #1 SMP PREEMPT Sat Apr 7 08:32:34 UTC 2018 x86_64 GNU/Linux
clauded99
Re: Error with snap
Postby Kate » Wed Apr 18, 2018 11:03 am
We have not managed to reproduce the problem. This problem can be caused by incorrect settings in your computer.
Kate
Return to Desktop Editors
