How to make data persistent and install on subdomain
La discussion des problèmes que vous avez rencontrés lors de l'utilisation ONLYOFFICE
bigdong
Message par bigdong » jeu. oct. 08, 2015 8:02 pm
Hi !
I am trying to install using docker-compose the onlyoffice suite on a server which has the hostname "mail.example.com"
The server which has the domain "example.com" is a different address.
I want to create email address for "@example.com", but only for @sub.example.com"
Here is my docker-compose.yml
Code : Tout sélectionner
communityserver:
  image: onlyoffice/communityserver
  restart: always
  links:
   - documentserver:document_server
   - mailserver:mail_server
  ports:
   - "80:80"
  volumes:
   - /opt/onlyoffice/Logs:/var/log/onlyoffice
   - /opt/onlyoffice/Data:/var/www/onlyoffice/Data
   - /opt/onlyoffice/MySQL:/var/lib/mysql
  stdin_open: true
  tty: true
documentserver:
  image: onlyoffice/documentserver
  restart: always
  stdin_open: true
  tty: true
mailserver:
  image: onlyoffice/mailserver
  restart: always
  hostname: mail.example.com
  privileged: true
  environment:
   - STORAGE_BASE_DIR=/var/vmail
   - FIRST_DOMAIN=mail.example.com
   - DOMAIN_ADMIN_PASSWD=D456aDZA1
  volumes:
   - /opt/onlyoffice/MailServer:/etc/pki/tls/mailserver
   - /opt/onlyoffice/VMail:/var/vmail
   - /opt/onlyoffice/MySQL_mail:/var/lib/mysql
  ports:
   - "25:25"
   - "143:143"
   - "587:587"
  stdin_open: true
  tty: true
I also had to do this on the docker host before to make the Data directory writable (not specified in the doc)
sudo mkdir -p /opt/onlyoffice/Data
sudo chmod 777 /opt/onlyoffice
sudo chmod 777 /opt/onlyoffice/Data
With this configuration, I am partially able to send email.
- I can only create a mail from the domain @mail.example.com and not @example.com
This config was working great on first install, but when i removed the image and kept the /opt/onlyoffice and recreated the image, I couldn't send and received mail anymore.
In all the documentation of onlyoffice they say to link twice /opt/onlyoffice/MySQL to /var/lib/mysql, one time for communityserver, one time for mailserver.
You cannot link two different database (community and mailserver) on the same host if the host directory is the same.
That's why i renamed the /opt/onlyoffice/MySQL to /opt/onlyoffice/MySQL_mail.
Katarina
Re: How to make data persistent and install on subdomain
Message par Katarina » jeu. oct. 22, 2015 1:59 pm
We would like to note, that this forum http://cloud.onlyoffice.org/ is devoted to discuss the questions regarding ONLYOFFICE SaaS version.
We invite you to leave your post on our another forum, which is devoted for ONLYOFFICE Free Server Edition: http://dev.onlyoffice.org/
Répondre
