Searching Tags
jvolkman
Searching Tags
Post by jvolkman » Thu Apr 04, 2019 2:51 pm
Please change the search function to allow 'and' and 'or' for tags. We need to be able to search more than one tag and any one of the selected tags related to a contact pull the contact. Without this function we are forced to look into other CRM database options as this a major shortcoming of OnlyOffice. Contact type, temperature and tags are the only ways to sort contacts to generate reports. This should be a very simple fix on the back end of the search bar. It would not be difficult to have two separate tag search functions one for 'and' and one for 'or'. This is a databases 101 request.
Kate
Re: Searching Tags
Post by Kate » Fri Apr 05, 2019 7:57 am
Thank you for your suggestion. Our developers will consider it.
