steps missing to install document server on CentOS
greavette
Post by greavette » Wed May 24, 2017 6:24 pm
I'm following the instructions to install onlyoffice document server (to be used for my Nextcloud) and there are steps missing to have document server autostart on reboot. Following this document:
https://helpcenter.onlyoffice.com/de/se ... entos.aspx
The 4 services that need to be started are:
sudo service redis start
sudo service rabbitmq-server start
sudo service supervisord start
sudo service nginx start
Upon reboot these services are not started and must be started manually (in the order listed above).
To ensure your document server starts correctly the following should be added to this instruction:
sudo systemctl enable redis
sudo systemctl enable rabbitmq-server
sudo systemctl enable supervisord
sudo systemctl enable nginx
Thank you.
Alex
Re: steps missing to install document server on CentOS
Post by Alex » Fri May 26, 2017 10:44 am
Could you please describe the issue on our Forum for server versions of ONLYOFFICE, as this Forum is for cloud versions.
Please follow this link: dev.onlyoffice.org
