Doc Versions?
RickMcK
Doc Versions?
Post by RickMcK » Sat May 18, 2019 8:20 pm
There seems to be several bugs.
1. the version number does not change when someone edits the document. It shows the revision in the expanded screen, however, the icon does not show the versions. Are we doing something wrong?
2. The reversions- versions do not show up on a doc when they attached to a task. The versions show up at the project level (with the same issue as in #1).
3. how to change an Admin to a normal user?
4. In adding some users they become Admins when I don't want them to be Admins?
Thanks
Rick
Project level folder.jpg (108.01 KiB) Viewed 1081 times
In task.jpg (51.67 KiB) Viewed 1081 times
