onlyoffice in Iframe
This forum is for general suggestions not relating to any particular section of the portal. If you would like to post an idea about one of the modules, please check the list of forums.
krisbee
Post by krisbee » Tue Oct 17, 2017 12:57 pm
We use OnlyOffice on cloud (hosted by OnlyOffice)
For our office intranet , I put in Iframes the links to some pages of our OnlyOffice.
It used to work perfectly.
But for unknown reasons, after the updates you did in September, the onlyoffice links in Iframes stopped working.
Would you know why and/or have an idea to help.
Thanks.
Kate
Re: onlyoffice in Iframe
Post by Kate » Mon Oct 23, 2017 7:44 am
We would like to recommend you contacting our technical support team via https://support.onlyoffice.com/ and describe the problem: specify more details and attach screenshots.
Our technical specialists will examine the issue.
