CRM OR vs AND 'with Tag' search function HELP!!!
Your ideas on the improvement of CRM module.
jvolkman
Post by jvolkman » Thu Nov 29, 2018 5:41 pm
Please add necessary functionality to the CRM search with the option to add more than one 'with tag' dropdown in the search bar.
The single 'with tag' functions as AND only which allows us to choose as many tags as desired but will only populate Contacts containing every one of the selected tags.
Simply adding the ability to add more than one 'with tag' drop down in the search bar would also give users the EITHER/OR capability when we want to search by multiple Tags and pull up Contacts affiliated in any way with just one of the multiple searched tags.
Please Help us be able to do this! Running multiple searches for each tag and dumping into jumbled 120+ long column excel spreadsheets is not a viable option.
It doesn't look like it would be much work on the backend of the database to edit the search bar to allow more than one 'with tag' search function.
It looks like it may just be a parameter set that needs to be changed that limits it to one per search bar.
Kate
Re: CRM OR vs AND 'with Tag' search function HELP!!!
Post by Kate » Tue Feb 12, 2019 5:20 pm
Thank you for your suggestion, we will definitely forward it to our developers!
If you have any other questions, please, ask.
Last bumped by jvolkman on Tue Feb 12, 2019 5:20 pm.
