Sorry, but this is my first attempt to use onlyoffice.
I was trying the cloud service.
I created a new document, and typed a equation as this
a + b = c
If I realize that the right side of this equation should be squared, I selected the "a + b" then I go to Equation menu, then Scripts, and Superscripts and ....
Then all selected part of the Equation is erased ! I had to write all the right side again. This is a simple example, imagine if the selected text(equation) is a complex one ! Well, you can say that I need to select the text to be squared (modified) and copy to the clipboard(control-C), go to te Equation and son on, and then copy (Control-V) to the empty space reserved for a SuperScript data. No it is not. It is not the easy way.
It seems to be a bug, doesn't it ?
Angelo.
Typing an equation.. is it a bug ?
Re: Typing an equation.. is it a bug ?
This is a normal behavior. We are currently working on ameliorating our formulas.
