korean input doesnt work well.
Your ideas on the improvement of ONLYOFFICE mobile applications / mobile version.
wingpgs
Post by wingpgs » Fri Jul 09, 2021 8:35 am
i use seafile cloud. and wanted to use onlyoffice android app to use docs in the cloud.
when i tried i coundnt use korean for documents and spreadsheet.
it occured both of my android machines tablet and phone.
Kate
Re: korean input doesnt work well.
Post by Kate » Fri Jul 09, 2021 9:52 am
Please clarify what exactly is the problem with typing in Korean? What result do you expect to achieve and what do you get in the end?
Best regards,
